Hey I'm Mud,
I have an 01 accent 1.5L manual. The check engine light came on and the engine is running doggy. I hooked up my obd II scanner to it and it is not communicating with the ecu at all. I borrowed my neighbors scanner, which is a higher end scanner (snap on) same result. I checked all ecu fuses and the connections in the data port, all good. Any ideas. I am perplexed, never had this happen on a car before.
l am moving your post over to the accent forum for a better response
