This forum has helped me many times prior to being a member. Thought I'd share a fix I made on my 2002 Santa Fe. Red oil leaking from tubing directly under the radiator. The tubing (2 tubes) was held down to the tray under the radiator by a fastener. Impossble to reach to remove hold down bolt. I removed front bumper & then bypassed the metel tubing with ATF hose(s) from the heat exchanger to supply and return line(s). I left in the tubing in place & secured the hose with hose clamps & wire ties to keep them secure. It worked great & cost me for two 5 ft lengths of ATF hose, about $35.00. Have a good day! FritzK
