81 - 100 of 107 Posts
gereral1 thanks for posting! My 2009 Hyundai Accent 1.6L is running rough and has low power, loss of power. The check engine light is on and the scanner is reading 3 codes: P0300 Random misfire, P0301 Cylinder 1 misfire and P0303 Cylinder 3 misfire.
So I've just begun my research and haven't run any tests yet.
I wanted to start with cylinder numbers and firing order, can't find any concise info at all for these years.
Thanks so much!
Discussion Starter #82
Thanks so much!
First test is when cars cold remove coils indpect them. Then plugs inspect them.
Then have a compression test done on cylinders. Take top timing cover off and check timing belt condition. If your not sure about these items I have detailed videos on youtube.
If coils are good, plugs are good and timing belt true and crank and cam are in time do a propane test on intake manifold and listen for change in engine rpm. If it changes your intake gasket may be suspect.
Last test is to have fuel pump pressure tested.
On the compression test this will test head gasket. Also you can perform a leakdown test if the compression test fails to tell if its gasket, intake or exhaust valves.
Another thing that can cause power loss is a melted or restricted cat.
Ask members in main forum as there are certified techs on here that can help further.
Discussion Starter #84
Photobucket defines 3rd party hosting as the action of embedding an image
or photo onto another website. For example, using the <img> tag to
embed or display a JPEG image from your Photobucket account on another
website such as a forum, auction listings, blog, etc.*
3. Benefits of Photobucket?s 3rd Party Hosting
Easy to Use ? Upload a photo from any device and copy the embed code with
one click to host a photo with no development or technical knowledge
required
Competitive, fixed pricing
Offers the only unlimited 3rd party hosting plan (Commercial and Personal
Use)
3rd Party Hosting Specifics
1. What plans offer 3rd Party Hosting?
Only the Plus 500 plan supports 3rd Party Hosting
Upgrade to Photobucket?s Plus 500 Subscription by visiting????http://photobucket.com/pricing
or http://photobucket.com/p500
2. What do I get with the Plus 500 Plan?
Unlimited 3rd Party Hosting
Unlimited Bandwidth
Full Resolution Photo Storage (We do not compress your images)
High Capacity Storage
Dedicated and Priority Customer Support
Photobucket.com Promotional Opportunities
3. What users are affected by the changes to our 3rd Party Hosting
policies?
Moving forward, new and legacy free account users will NOT have third party
hosting available.
If you were a Plus Account subscriber in good standing as of June 1, 2017,
you will continue to have all the privileges you have enjoyed including 3rd
Party Hosting until December 31, 2018 as long as you maintain your
subscription.
Non Plus 500 Account subscribers that purchased after June 1, 2017 will not
have access to 3rd Party Hosting.
4. Are my pictures still safe?
Bullshit. Now all my pictures and tutorials on here wont show up. Nice one photobucket. Hijack all my photos
Yes! All your photos are still available by logging into your Photobucket
Account. Photobucket has only restricted the ability to view your photos on
3rd party sites.
Discussion Starter #90
It sounds like clunk clunk I fist thought my stabilizer linkages were bad but to my surprise it was hanger. Jack your up. Check stabilizers with Both fronts on jack stands. Ball joints can make noise but symptoms include steering wheel vibration, up down movement when testing tire 12 6 position. Also failed wheel alignment (s) is another sign. Failed cup ends (bearings) at top of the struts can make mysterious sounds going over bumps. Motor mounts but very unlikely
Discussion Starter #91
Loose items like jack and bar of tire lock nut loose in trunk can cause noises. Glove box, stuff in your door pockets...
I simply wanted to know if you had audio to go with the specific noise you were repairing lol, that's all.
Have you experience with a P2177? I understand the general idea of it, but I can't seem to find anyone with an Accent that has had that code.
It's come up in the past before and went away by itself. Now it's constant and I am sometimes getting the hard start.
I've swapped some stuff out and nothing has changed. I'm not particularly ready to point to the fuel pump yet.
Discussion Starter #93
Hyundai manual in dtc codes does not list this but it links to generic obd code for problems with fuel system ex. Fuel injectors, fuel pump pressure issue or wiring to these items
What about doors, I know my old manual window 240sx was wired for power doors.
I have manual windows/mirrors, but the junk yard has a nice pair of power doors for only $180. Does Hyundai happen to follow the same path with wiring? Or am I looking at wiring them up myself.
Would be awesome to just be able to route the harness into the cabin and find a connector there waiting? Searching turned up nada on the matter.
Discussion Starter #95
When I get home tonight I'll upload wire harness pins and color wires for power windows . The loom is in the rubber goment between the door and inside body of the car. The plug is in that loom.
Cool so it is in fact pre-wired on all vehicles regardless of whether the doors are actually power?
Discussion Starter #97
This video may help out users who have issues with their nozzles. I show you how to access the panel and aim the fluid target.:smile:
Window washer series new upload. Check out my site in my signature to watch the videos. Have problems with your hyundai washer multiswitch? Learn how to troubleshoot yourself. Enjoy and dont forget to subscribe. Peace......
Discussion Starter #100
This was already posted but incase the thread gets lost this is my current status with 2019 Hyundai Accent......
Sad to report but its time for a new car today. Bought a 2019 Hyundai Elantra Preferred fully loaded. Comes with sealed transmission and timing chain so no need to do timing belts anymore. I will still help people here. I have parts that are available at a big discount if anyone wants to talk to me. Shocks and stuts and end caps, bearings, and hoses for the throttle body and transmission lines. Also have a thermostat and gasket for it as well. PM me if your interested. As for any help with Hyundai accent 2006-20111 I will help out any with any questions. Thankyou admin for sticking my main post and videos to help people on here. Eventually you will see me over at the 2019 Hyundai Elantra forums helping new people out as well...….. The thing I noticed is the engine is coil over just like the accent so spark plug replacement in easy. Transmission is gravity fed and the timing belt is not rubber which is a great thing. The brakes are pads front and the rear are drums on the back. Has all this crash warning stuff and heated steering wheel and seats. Nice in dash display and three modes of driving and an option to switch to manual mode but really looks like a gimmick. HAs eco mode and normal mode and sport modes. The power steering is motorized and no fluid container and the throttle is electric so no more cables. Show total klm left on a tank of gas and hands free Bluetooth phone options. Cruise control and leather steering wheel. Look for my detailed review and drive testing on this car coming soon...…..
