New member here and tried searching to see if someone had a similar problem to what I'm having but didn't see anything. I've got a 2014 Santa Fe Limited where the driver side HID headlight went out. I have tried to replace the bulb itself but that did not work. I have checked the fuse as well as tried the relays. At this point I'm not sure what to do next. Don't want to take it up to the deal as I'm sure that wont end well.
Can you check to see if you have any voltage going through the low beam harness? Just curious because that will tell you if the connection are still good.
