Hi,
I have a 2013 Hyundai i20 which I bought a week ago.
The braking power in general is ok, but not great.
Also the handbrake lever is too easy to pull up. And when I parked uphill this weekend, the car was rolling away even though the handbrake was fully engaged.
Yesterday I decided to inspect the brakes. The front brakes (pads / discs) are in good condition.
The rear brakes are bad. The pads are okay but the disc is worn down quite a lot and has a relatively high edge on the outside. I decided to replace the discs, pads and handbrake shoes.
I bought the following:
I did not buy a new handbrake shoe adjustment screw. Even though it would have been better. On the driver's side, the 'screw' part of the adjuster works (turns) but the other side (the one that should be freely turning) is stuck. So it cannot be adjusted when it's installed.
I installed the new brake shoes, I put the adjuster screw on the smallest position (completely screwed in) and I even loosened the handbrake cable inside the mid panel.
However, when installing the disc over the new handbrake shoes, even with the handbrake not engaged, it is VERY hard to get the disc on there and after that to turn it. So the handbrake shoes are making too much contact.
Do you have any ideas what to do? Both adjustments (shoe adjuster and handbrake cable) are very loose. So I don't know what to do anymore.
I saw a tip online to grind down the metal part on the shoes where the adjust fits, to make it even smaller and make the shoes be closer to eachother (decreasing the diameter of the entire braking-shoes circle. Is that smart or..?
Also, even the adjustment screw cannot be adjusted when installed, is that necesarrily an bad thing? Right now the smallest position already seems to big, so it seems fine to me to not be able to adjust it easily.
Any tips are more than welcome!
- New handbrake shoes
- New handbrake shoes fitting springs/pins
- New discs
- New pads
