Hi
I recently put a new clutch in my accent and im getting the same problem that i noticed before i the clutch replaced , basically i have to depress the clutch the whole way to the floor to change gear , is this common with accents or is there something that can be done to give more play in the clutch?
thanks for your time
Take and adjust the pedal slop to get rid of pedal slop,, and get the most of your hydraulic movement...
sorry for the slow reply ,the problem came from the clutch slave cylinder. the seals had burst and the fluid was leaking, fix the problem in 20mins and it cost me €15 and now thew car runs perfect :D
thanks for the suggestions
