Need Help With Windshirls Washer
1083 Views 3 Replies 3 Participants Last post by  sbr711
hello everyone,
i have a 2004 Tiburon SE and recently my front windshield washer spray does not work but the rear does. i haven't had time to do much looking around under the hood but i did disconnect the hose under the hood and when i tried the spray nothing came out of the hose. from this do you think its the pump? do the front and rear jets use the same pump?
Thanks
Front and rear have a different pump. You'll have to take out the old pump, I think you have to remove it from underneath the car, it's under the fluid reservoir. Verify power goes to the pump first, if power is ok, then the pump is bad.
ok thanks man
Car has 1 washer pump, 3 wire plug.
98510-2C100 MOTOR & PUMP ASSY $62.76
We have (1) on the shelf....
