Hello,
So I've been getting this code PO0711 Transmission fluid temperature sensor on my girls 2007 Tiburon GT Automatic, took it to the shop they told me they changed the sensor but I keep getting the code after computer has been reset. Has someone deal with this issue. :crying2::crying2::crying2:
Unless they dropped the Tranny pan they never changed it! Did you get the old sensor back they supposedly replaced? If they did change it the code wouldn't be coming back! Regardless take it back and tell them to actually fix it this time.
Well I think they did change it, took it back, but nothing. So at this point I'm just trying to see, if someone else had this problem and fixed it.
Do you always give up easy? If they replaced a part that was suppose to clear the code since it was diagnosed as that sensor MAKE THEM fix it. That's the only sensor that can throw that code.
