1 - 20 of 22 Posts
No numbers, the vehicle is overseas, identification help is needed just through these pictures
Can anyone please help identify this engine?
Yeah, it's a Mitsubishi 4D56, 2.5 Diesel. Probably fitted to a Hyundai Galloper, aka Mitsubishi Shogun/Pajero/Montero
I'm curious, is there a particular reason you need to know? I assume you are searching for something in particular?
It's diesel, that's the first clue
Thanks Autospark, if correct, how do I explain the KIA and Hyundai markings on the valve cover?
Thanks Gerard 2 - yes I need to identify the engine to get several
Watch Sky Plant Gesture Automotive tire
parts. I especially need a clutch release bearing. The vehicle is overseas.
Discussion Starter · #8 ·
Because the clutch bolts to the engine and since the engine was taken out of another (unknown) vehicle, my best hope for getting the right part is by identifying the engine
Thanks Gerard 2 - yes I need to identify the engine to get several View attachment 462198 parts. I especially need a clutch release bearing. The vehicle is overseas.
Keep in mind a lot of Hyundai/Kia product used Mitsubishi engineered powertrains so it will be same in appearance but manufactured in Korea under licence I guess so that would be why. I was about to head down the Mitsubishi path myself but Sparky's experienceis likely why he's immediately recognised it and suggested 4D56. The 4D56 is in fact mentioned in the Hyundai service manuals for a lot of models fitted with the D4CB a Hyundai 2.5L Diesel variant as it appears they fitted either at some point.
If you clean up that bearing could there be some part numbers on it?
I'm still struggling to help you though, I could do better if you know what vehicle we're dealing with or what parts exactly. Knowing the transmission type would also be helpful. Or the model year
If you can get identifying part numbers off the clutch I may be able to revers search that way vehicle type or post images of what you see, if it's OEM parts.
HYUNDAI
  • HYUNDAI H100 Minibus (P) (Year of Construction 07.1993 - 10.2004)
  • HYUNDAI H-1 MPV (A1) (Year of Construction 06.1997 - 12.2007)
  • HYUNDAI H100 Van (Year of Construction 07.1993 - 12.2004)
  • HYUNDAI H-1 Van (A1) (Year of Construction 10.1997 - 04.2008)
  • HYUNDAI Galloper II (Year of Construction 02.1997 - 12.2003)
  • HYUNDAI Terracan (HP) (Year of Construction 06.2001 - 03.2008)
  • HYUNDAI Galloper I (Year of Construction 08.1991 - 07.1998)
MITSUBISHI
  • MITSUBISHI L300 / Delica III Minibus (P0_W, P1_W, P2_W) (Year of Construction 11.1986 - 12.2013)
  • MITSUBISHI Starion (A180, A187) (Year of Construction 05.1982 - 06.1990)
  • MITSUBISHI Pajero / Shogun I (L040) (Year of Construction 04.1982 - 12.1991)
  • MITSUBISHI Pajero / Shogun II (V20) (Year of Construction 12.1990 - 10.1999)
  • MITSUBISHI Pajero / Shogun III Off-Road Convertible (V6_W, V7_W) (Year of Construction 04.2000 - 12.2006)
  • MITSUBISHI L200 III Pickup (K6) (Year of Construction 01.1996 - 12.2011)
  • MITSUBISHI L300 / Delica III Van (P0_V, P1_V, P_2V) (Year of Construction 11.1986 - 09.2013)
  • MITSUBISHI Pajero / Shogun I Canvas Top (L040) (Year of Construction 12.1982 - 11.1990)
  • MITSUBISHI Pajero / Shogun II Canvas Top (V20) (Year of Construction 12.1990 - 04.2000)
  • MITSUBISHI Lancer IV Hatchback (C6_A, C7_A) (Year of Construction 04.1988 - 05.1994)
  • MITSUBISHI L300 / Delica II Platform / Chassis (L03_P) (Year of Construction 05.1980 - ...)
  • MITSUBISHI L300 / Delica III Platform / Chassis (P1_T ) (Year of Construction 04.1994 - 04.2000)
  • MITSUBISHI Pajero / Shogun Sport I Off-Road (K70, K90) (Year of Construction 07.1996 - ...)
  • MITSUBISHI L400 / Space Gear Minibus (PD_W, PC_W, PA_V, PB_V, PA_W) (Year of Construction 06.1994 - 04.2007)
  • MITSUBISHI L400 Van (PAO) (Year of Construction 12.1994 - 04.2007)
Discussion Starter · #17 ·
Thanks for all of the information and photos. The engine was transplanted into a Montero, but from what vehicle is unknown other than supposedly a Hyundai. Since the vehicle is overseas, I have no access to it. I only have the photos I shared.
Well if you find out more we can tell you more I guess but Montero = Pajero for us here. first Pajero sold here was in 1983 NA series with 4G54 and 4d55T motors. 1986 we got the 4D56T and then 1988 the 6G72 .
  • Mitsubishi Montero
  • Mitsubishi Shogun
  • Colt Shogun[12]
  • Dodge Raider
  • Hyundai Galloper
  • Jinhui Mitsubishi Pajero (China; JV
Wikipedia
If you can get the VIN of that vehicle we'll know everything about it parts wise including what it was in.
Discussion Starter · #20 ·
Thanks Gerard 2, the donor vehicle is unknown so no VIN there will be available. However the following was found on the block just above the exhaust manifold 7B130458B2. 266
Does this have any meaning for you?
Thanks!
1 - 20 of 22 Posts
