It never fails. new line, they remove things that should not be removed. I'm still trying to figure out who's idea it was to omit the glove box light and the trunk handle (inside the trunk to avoid leaving hand prints on the exterior of the trunk).
Hyundai Parts - Genuine OEM Hyundai Parts and Accessories Online (hyundaipartsdeal.com)It looks like Hyundai has removed the Homelink mirror from the standard equipment and moved it to a dealer installed option. Do you see anything else that has changed? Also, what are some of the discounted online parts sites for genuine Hyundai parts? I've seen a couple mentioned but can't seem to find them right now. Thanks
Not sure what you’re talking about. The mirror with Homelink is available on the SEL with Convenience package and higher trims. It’s not a dealer-installed accessory. See price sheet linked in the first post of this thread.It looks like Hyundai has removed the Homelink mirror from the standard equipment and moved it to a dealer installed option. Do you see anything else that has changed? Also, what are some of the discounted online parts sites for genuine Hyundai parts? I've seen a couple mentioned but can't seem to find them right now. Thanks
Not quite sure where you are seeing this, on the USA Hyundai site the mirror with homelink is listed as standard equipment.It looks like Hyundai has removed the Homelink mirror from the standard equipment and moved it to a dealer installed option. Do you see anything else that has changed? Also, what are some of the discounted online parts sites for genuine Hyundai parts? I've seen a couple mentioned but can't seem to find them right now. Thanks
I see that now. That is weird, maybe a mistake? It is listed as standard equipment on several models including the SEL Plus, N line and Limited. Not sure about the other models, can't seem to compare those right now.Build Your Own Hyundai | Hyundai USA
Listed at $295, along with other assorted items such as cargo items, all weather floor mats, etc. that are normally dealer added.
Thanks, I'll keep that in mind.after we bought the elantras, i bought a homelink mirror kit on ebay for 30 bucks. genuine
Hyundai's site shows that the Limited has the full LED headlights (all the way across rather than halfway or part way), but the N-Line does not. Is that accurate?Some additional Limited things...
- Blind View Monitor
- Ambient Lighting
- Both have Full LED Taillights
I believe so as it is based on the SEL. It's a bummer for sure. Plus just looking at them they don't look like the Limited's.Hyundai's site shows that the Limited has the full LED headlights (all the way across rather than halfway or part way), but the N-Line does not. Is that accurate?
Still 1110+ miles away will check this site to see if I can drive one of the first ones on the West Coast..thanksNice to see some N-Lines hitting the dealers around the country. There was one listed on cars.com as "n-series"... amazing that the first dealer to post one in stock with pictures botches the description.
Seen some price variations as well, one already discounted to $30,352 and others at MSRP, before most have even hit the lot. Go to cars.com and search new Sonatas and go into keyword box type in "n-line" or "n line" and change to exact match or else it won't work. All car sites I have searched, including Hyundai's page, do not list "N-Line" as a trim option to search for inventory so until they do, this search is the only way I know how to do it.
Here is the "N series" description, the first actual pictures posted by a dealer that I have seen.
Hope the links work.
There's standard reflector led's and then the adaptive type on the Limited which change their pattern based on traffic ahead. I believe the n-line has the former.
Came to say the same thing. They are "matrix style" but can't function like the matrix lights in other markets because the NHTSA doesn't allow these types of lights on the road yet. The Limited lights cast a slightly wider (think cornering lights without the actual separate corner bulb) and possibly slightly longer beam which is why they rate better than the models below the Limited. I can't find the link to back that up at the moment.they have auto high beams and are nicer than the other trims, but aren't adaptive.
