I recently changed the folding gear inside the mirror of my 2011 santa fe. Now the right side view mirror opens and closes perfectly with the open close button on the drivérs side. I have this issue with the left mirror which does exactly the opposite. When i press open it closes. Hence i have the right mirror open and the left mirror closed when the button is on open position. Would anyone please be able to guide me to set this problem right.
Thanks, not sure which wires to switch. I havent touched the wiring at all. Any detailed explanation will be highly apprecaited
The two wires that connect to the fold motor on the left hand mirror. That should cause the fold motor to operate in the opposite direction, which will cure the problem.
