hello,
I'm Ryan and I've had the Santa Fe bug for a while now, my mom got a used 2007 gls back in 2010, my dad picked up a 2011 limited back just a couple years ago. so when i went looking for my first car i decided to keep the santa fe in mind, but also wanted a manual as my first car since i've been driving automatics for years. so to my surprise after a couple weeks of looking here and there i found my unicorn. a 2009 2.7l 5 speed manual in dark red. i bought it back april of 2019 with 215k km and has been a pretty smooth ride thus far up to 240k km only one failure being the slave cylinder blew resulting in a visit to the shop, and the common fuel level sensor and fuel sender unit fritz that i fixed myself, only grip is the 2.7l engine can make this car feel like a lazy dog some days not to mention the marriage of the computer controlled throttle body to the transmission giving inconsistent power bands
i've been diy'ing all the maintenance and have flushed every fluid sept for the coolant. installed a sub woofer. and am currently trying to catch up on the rust work that is pilling up as this car hasn't been rust proofed at all of its 10 years and being in the rust belt i do have a decent hole coming out the uni body cross member. imo it's an easy car to work on and something im putting the effort into preserving. i have parking brake cables to swap out the seized cables this coming week and am going to take further note of my under carriage then.
decided i was fixing a paint bubble on the lower fender one day. got close enough i had to take off the mud guard then the sub guard pulled back the wheel liner and the dirt was packed in there up a little higher then the white you see inside the wheel well. while i had the fender off i seized the opportunity to continue the body job. paint is pearl white with a pearl over spray for that extra pearl depth so many manufactures lack. although im going to need to rework just above the headlight as the paint line doesn't follow the line coming from the grill. eventually a stripe to the back tail gate where i have painted the rear emblem pearl too
i also got a new wiper cap to swap out, and will try some plastic rejuvenator out on the sun bleached wiper arm.
an older pic since then i drilled and ran the sub wires through the hatch door for a tidier setup, under neath is a alpine mrv 500 mono amp. so far no issues with heat being in such a confined space and it rocks good just being at about the limit for the alternator
right now I'm also wanting to go camping out my car and am working out a setup to do it. with the back seats down an air mattress fits perfectly in there. as for air flow i bought window vents, and am going to make magnetic window screens. maybe take out the smaller rear seat for storage but ideally i want everything to fit in the back compartments currently in the back tote from right to left i have.
thank you guys for taking a read.
![20200314_163925[1].jpg](/d1/attachments/105/105235-af7f65b7ec94e271f4b35881db1d8eb0.jpg)
- toilet paper
- air mattress
- mattress infiltrator
- 20ft booster cables
- socket set, under air mattress
- box of oat meal.
- looking at a camping stove
- pillow
- sleeping bag
- first aid kit
- pan/ kettle/ cups
