I need help in fixing my vehicle. The problem is that it idle high and low. It will cut off at times when I stop at a traffic light or stop sign. It can be idling fine and then the engine will rev-up high, going back and forth. I have bought everything i could think of, such as, 1. Intake manifold gasket. 2. Throttle position sensor. 3. Idle control valve. 4. mass air flow sensor. 5. Purge valve. 6. camshaft position sensor. 7. crankshaft position sensor. 8. air rubber intake hose. 9. throttle box. 10. fuel pump and assembly. and then i bought another idle control valve because I was told that it could still be bad.
I have ran out of what I need to do.
Welcome to the forum. But your asking for help in the wrong place. Not many Santa Fe owners will be reading the Forum Rules. It would be better if you could repost your plea for help over on the Santa Fe Forum
