Good morning! New to the forum here. I have a 2014 Santa Fe Sport 2.0T and the scanner is reading wheel speed sensor failure for both rear wheels. As well as pressure sensor failure. When my wife initially called me, the gauge cluster was going nuts. Speedo needle was bouncing all over the place and the service notifications were flashing crazy like somebody poured water in it or something. Once I cleared the codes everything calmed down. Any advice on how to diagnose the problem would be helpful. Strangely, I replaced the right rear hub assembly less than a year ago, so I can't imagine the sensor is bad in that one already. Just wondering if anyone has experience with multiple speed sensors going bad simultaneously.. or if maybe there's an electrical problem? thanks in advance.
458390
458391
458392
458393
458394
458395
458396
Well I test drove it a few times but no more codes. However, later it wouldn't start at all. Turns out the battery was completely dead. New battery and no more problems so far. Will update if anything happens.
