1 - 8 of 8 Posts
have replaced radiator, injectors, pump, shaved head as none available at time all hoses but still boil when towing van for medium distance the vehicle then looses power and motor cuts out very dangerous when on free way and also in traffic in only one lane vehicle is turbo diesel crdi 2.9 lt 2005
yes the thermostat has been replaced and honestly I do not know if fan cut in they were replaced 2 odd years ago I an thinking a low water level thermostat might give early indication of boiling?
Whats a low water level thermostat? Just let the engine idle with the air con off and you'll soon find out if the fans work.
A low level thermostat lets you know when the water is low ...its put in between radiator and motor.... Thanks for fan info
A diesel engine left to idle will usually cool down on its own.
A petrol engine will usually warm up but is not the case here.
1 - 8 of 8 Posts
