When the weather gets warmer I'm going to add one of these...
Running wires through the only pass-thru in the car is a real PITA. I have 2 extra wires I ran through the last time I added wiring. I'm going to get a 10 GA wire, put it on it's own fuse and then pull it through using one of the wires already there, and then attach it to this, probably in the driver's side kick panel, if there is room. I have been thinking about maybe upgrading the radio with an amp, doing some lighting and after that, who knows?
These are made for boats, and are water proof. There are others as well, even better than this one (Look up Blue Seas fuse block) with 4, 6, 10, and 12 fuses for whatever you might want to power. Sure beats trying to pull wires through that pass-thru every time you want to add something.
Discussion Starter #2
PS: You can also get them with a Negative connection point as well, to eliminate seeking out grounds.
