If I had time, I'd search it using the search function. You can do this using search words like "mirrors," or "turn indicators." These might get you there. know this has been discussed on the Elantra forum and there are some step-by-step guidelines posted by other members that have done this.
Also - on the Accent, unless they added them in 2014, you couldn't get mirror repeaters in the USA from the factory.
It might be significantly easier (but more expensive) on an Elantra as you should be able to use the mirrors from a (2014?) Limited and just add the required wiring (if necessary).
