361 - 380 of 402 Posts
2015 Sonata Sport:
Leased 10/02/15 and purchased 9/02/2018 with 21,000 miles.
Presently has 30,600 miles as of today 02/13/2020.
Had all recalls,updates done including the 953.
Put on about 9,000 miles after the 953 update .
No problems so far!
2018 2.0 Limited bought in Dec. 2019 with 17,000 miles on it. As of 2/20 I've put 2000 miles on it with no problems and it has not used a drop of oil.Sold my 2015 Sport that also was problem free.
Just passed 70 000 km (43 500 mi) today with mine. ‘15 Sport 2.0T Ultimate bought at the end of May 2019 with just under 42 000 km (26 000 mi). Will need to go to the dealer soon for a rear suspension rattle and coolant leak from the lower radiator hose while I’m still under the Hyundai warranty, but with the relatively high mileage I’m putting on it during the winter with bad roads it has been very reliable. I did have to get replaced the turbo inlet hose because it was melted and the front door handles replaced because the black buttons for the keyless entry wouldn’t work, but it was like that when I got it. Even got the 953 update a week after getting it without any issues. Doesn’t use a drop of oil and other than the infamous e-CVVT plug letting go after a few cold starts near -40°, I’ve been loving it. Nice upgrade from my ‘09
  • Like
Reactions: johfed
2017 Sonata Sport 2.0T
He went over 70mph? I would never take pics of my dash while im driving on the interstate.....thats called evidence down here. I kid I kid....i was wondering what he meant as well.
If it is devilish to go over 70 mph I guess Im already confined to **** because my daily drive 65 miles one way in the am is at 75-90 mph just to stay with the flow of traffic.
Same here...i cant get the car to cruise slower than 85
2015 Limited 2.4
215,578 miles
Holy moly, you were the highest posted mileage last time you updated, and now you just went even higher. How’s your car holding up? Any issues?
Discussion Starter #375
Purchased car on February 13,2017
1700 miles April 1st 2017
3829 miles May 1st 2017
5403 miles June 1st 2017
6800 miles July 1st,2017
8501 miles August 1st, 2017
10,150 miles September 1st,2017
11,150 miles October 1st,2017
11,950 miles November 1st,2017
12,700 miles December 1st,2017
14,020 miles January 1st,2018
14,540 miles February 1st,2018
15,025 miles March 1st, 2018
16,400 miles April 1st,2018
17,200 miles May 1st,2018
18,000 miles June 1st,2018
19,200 miles July 1st,2018
21,500 miles August 1st,2018
22,500 miles September 1st,2018
23,300 miles October 1st,2018
24,400 miles November 1st,2018
25,000 miles December 1st,2018
26,000 miles January 1st,2019
26,650 miles February 1st,2019
28,150 miles March 1st,2019
29,940 miles April 1st,2019
30,940 miles May 1st,2019
31,440 miles June 1st,2019
32,000 miles July 1st,2019
34,920 miles September 1st,2019
35,700 miles October 1st,2019
37,000 miles November 1st,2019
37,680 miles December 1st,2019
39,200 miles January 1st,2020
39,980 miles February 1st,2020
41,340 miles March 1st,2020
12/19/17 12,847 miles...Factory Recall-70C097R2-Sonata Inhibitor Switch Replaced (17-01-064)
*Highest mileage forum member LF Sonata reported by LknBigFish with a 2015 2.4L with 215,578k miles dated 2/25/20.
5/11/20 = 98,400 miles
2017 Sport 2.0T purchased new May 2017 (3 years old this month), avg daily commute 135 miles RT - 5 days a week 85% freeway 65-85 mph. Spirited driving most of the time in "sport" mode and manual or using the paddles to shift, rpm greater than 4,500-6,000 for acceleration shift points.
Using Hyundai Filters and Mobil 1 5-30 OCI every 5,000 miles
Maintenance / Repairs
First 1000 miles oil and filter change, Mobil 1 5-30 and Hyundai Oil Filter
OCI 5,000 miles Oil / Filter changed with Mobil 1 and Hyundai Oil Filter, tires rotated
Air and Cabin Filters changed every 15,000 miles (every 3rd service)
20,000 replaced grille due to road debris damage
35,000 Alignment done - lf front out of spec
44,000 Transmission fluid changed - complete flush with Hyundai Fluid
Spark Plugs (NGK) changed at 44,000 miles
48,000 (12/22/18) Replaced front bumper cover and grille due to chunk of steel on freeway thrown up by the car in front and broke grille and tore bumper cover. Pre painted Bumper Cover aftermarket and M&S Grille
50,000 Sumitomo HTR P2 All Season 245-45-18 tires replaced the OEM KUMOs, Alignment Courtesy Check by Dealer - within specs
55,000 Brake Pads replaced with EBC Green Stuff Pads (nothing done to rotors)
60,000 Coolant Service (953 recall performed)
65,000 during routine oil and filter change I noticed the undercover had pulled away from 2 of the 10mm bolts and was loose. Replaced all bolts using "fender' washers to give more surface area to hold the cover up under the car.
72,000 Replaced EBC Green Brake pads with Powerstop Z23 carbon fiber ceramic. rotors still in speck and no hot spots so they were left alone. Car stops better than OEM
75,000 installed AEM Strut bar. purchased off Ebay NIB from private seller $ 50.00 plus shipping. Easy install, looks good but honestly I dont feel any difference in handling, response etc. Shocks still feel good and no leakage.I may replace them soon with ARK lowering springs 1" and Truhart Shocks. Replaced Low beams with PIAA Xtreme 9005 bulbs, tried Beamtech and Hikari that were a match in color for the DRL but did not throw enough light IMO so went back to halogen with the PIAA in low beam and I had already replaced the High Beams with Sylvania.
80,000 mile service did all filters, oil and Techron in the tank and a CRC GDI Intake Cleaner. LED interior, trunk and hood lights added. EBay LED kit for Sonata 11 bulbs for $ 10.40 they are currently all working and add a very white light.
85,210 Cabin and air filter changed, tire rotation, brake check. took into dealer for free mulitpoint inspection including check alignment (OK)
90,010 CRC GDI intake cleaner , BG 44k in the tank.
95,201 CRC GDI intake cleaner, new spark plugs NGK OEM, Truhart Sport Shocks and Struts with God speed 1" lowering springs installed between the 95,010 and 95201 service, alignment checked and within specs.
97,000 changed both belts - serpentine and water pump stretch belt using OEM. Transmission Fluid flush with OEM Fluid
98,400 Brake Fluid Change (improvement in brake pedel feels more firm), oil and filter, cabin filter, rotation. 2 nd set of Sumitomo HTR P2 245/45/18 tires, got about 48,000 miles out of them and they still had 2/32 left but my tire guy had a great price on them again and said the prices would probably go up soon so I replaced them. Ive been very happy wth them, quiet, great traction and considering my driving style and mileage they held up well.
5 TSB performed - Alternator Bolt, Inhibitor Switch, ECM Update, 953 Recall
No oil consumption, no problems. Drives better than day 1, the suspension was a great improvement in handling.
444460
2019 Sonata Limited Luxury...1995 Skyline R33 GTR V-spec.
19' Sonata just turned 27,543k's on the odometer!!
2015 Sonata Limited
I bought my 2015 Limited back in February of this year with only 9,725 miles on it; I've since put a little over 1k miles on it so we're coming up on 11k. The car had two previous owners, the second of whom lived in NYC and only used it on a rare occasion, putting 1.3k miles on it over a two year period. Really excited to be able to take this car on some road trips and get that odometer a little higher! 😊
