hi, before i made a post about not working MIL indicator light on dash.
the thing is that i spend all the water from the windshield washer and the low fluid level warning indicator light never came on dash.
So the 2 issues are related.
Is there a connector or something that i can check for myself?
i check the led that operates this two indicators light on dash and it's seem to be working perfect. (i change possitions one for other in the same dash)
thanks.
Check the plug. (for windshield washer)-
Once I had to clean the washer´s pump filter, I unscrewed and removed the pplastic cover under the right fender (first, turn the steering wheel al way right, to make space).
After pulling the plastic protector, check the white box (washer fluid tank and 2 plugs. One is for the pump - right -
and the other is bottom (near the right light fog , it`s orange). Check is in working condition. This switch triggers a light when the remaining fluis is less than 650 cc.
Hope this helps..
Bye
