i know some on here has hooked up a mega squirt on there 95 scoupe turbo
i realy need some help with the wireing and sensors
is there any sensors i need to get or can i use my factory ones
and tuneing wise does anybody have a basemap for me to avoid the hours of setup
thanks gents.
QUOTE (Automatik S-Coupe @ Nov 2 2010, 12:51 PM) index.php?act=findpost&pid=368359
you could use all standard sensors from scoupe... the only new one you need is the air intake sensor!
ok thanks but theres a few things i cant understand from the wireing diag.
or the harness there are only two injector wires and it shows that each wire controls 2 injectors
i dont like that idea is there a way to have individual control
and how do i hook up the ignition
the mega squirt diagrm shows a negative to a coil witch would be for a distributor engine
and my car is wasted spark how would i go on that
thanks for your help
individual fuel is not possible! Even KMS has only one wire for all injectors..so megasquirt is not so bad...
for the wasted spark you have to use a ford EDIS module if I remember correctly!
