I have a 2003 Santa Fe. I can't figure out how to get at the burned out map light bulb. The light I'm talking about is on the ceiling in front of the rear view mirror. There are two of them that you push to turn on and off. Any help is appreciated.
If you run along a finger nail(where the white plastic houses the bulbs) along the seam next to the gray you will find a half inch long gap toward each side. If you insert a knife/screwdriver into that slot and pry backwards and pull down at the same time it will partially come down. You kind of have to do it to both sides until it snaps out.
