I have a 2011 Sonata with a manual transmission, kinda rare. To shift into reverse you must lift up on the little ring. Well, mine is broken....not the ring. You can literally shift into reverse trying for 1st. Also, shifting to second is tricky. I have not yet driven backwards when I intended on going forward, so I am not sure if it is a big deal. Has anyone else had this problem? Was it a simple fix? I hope this is not internal transmission issue.
Thank you,
Ken
Discussion Starter · #2 ·
Update, took it to the dealer. It is a $9 part and $40 labor to fix it. They are keeping it a while. There are several open recalls out at the moment.
Good to know, mine works, but if it ever broke, I'm glad it's a $50 fix.
One thing I do frequently is going from reverse to 3rd rather than 1st. You realize it pretty quickly when you let out the clutch and nothing much happens. Put clutch back in, shift to 1st, then go.
