41 - 46 of 46 Posts
Obviously a typo there. Both those wires couldn't have been on pin 2. The +12V should be pin 1 and ground should be pin 2, according to the diagram at post #13.
MAP/Boost pressure sounds OK. 100kpa = 1bar, so it's right where it should be.
Did you check the boost pressure/MAP during test drive? Get the car into 4th gear then floor the throttle and see how much boost is shown. You should see about 200kpa if the boost pressure system is working properly.
Discussion Starter #46
took car for a run, map ran up to 218 kpa, at one point would not go above 40mph,slowed down turned round and went up to just short of 50mph, map 118 - 218kph
41 - 46 of 46 Posts
