Hi just purchased an y reg amica for the neice
Just given it a full service
plugs /air / oil and fuel filter.
but have found a ! missfire or hesitation at about 2000 rpm
Put a new set of coils on to no avail.
Have scanned it come up with ramdom missfire and 2&3 missfire.
unfortunatly i cannot get a list of peramitter of the engine on the scanner. just the basics.
leads seem to be the next step but dont like just replaceing this to try.
Can anybody give me a lead.
scan codes are P0300 P0302 and P0303
My wife's Amica had a misfire, mainly on cyl 3, and after replacing the usuals I eventually tracked it down to blocked injector filters. The rail and injectors are easy to remove, and the filters can be wiggled out with a flat-ended no.10 screw and pliers. The filters can then be cleaned with Redex or WD40. Worked a treat. No.3 was almost completely blocked then no.2 started throwing up an error too so I cleaned them all out. No problems since.
