1 - 1 of 1 Posts
Hi,
I have a Terracan 2006 and from some time until now, when I start the engine after the 3 seconds after of the preheating coil light turns off, the motor starts but with low idle and the motor make some jumps until I press slowly the gas pedal for few seconds.
Someone could help me with your comments about this change in the start idle ? Before this situation the motor started almost at 900 rpm and later when the temperature raised the motor went to 800 rpm approximately. Now the motor starts at 700 rpm approximately.
Can I modify the start idle for this model ?
Thank you in advance !!!
1 - 1 of 1 Posts
