Hello. I recently(two days ago) had to replace my headlight sockets due to them having melted over the course of 165000 miles of mostly nighttime driving. After replacing them, I have noticed the low beams are not turning off when the high beams are on like normal.
When I replaced the sockets I encountered an issue with the wire coloration - it did not correspond to the connections on the old sockets. Red on the new connected where green was on the old socket and vice versa(blsck lined up properly).
I connected based on where the corresponding wire connected on the old socket rather than by color. Could this be causing the problem?
Thank you in advance for any help you can provide.
