New member here.
I have a 2004 Santa Fe and both of the head light(low beams) will not work. The high beams are fine, but the low beams just randomly stopped working. The fuses look ok and I can't see any visible damage to the bulbs. Both low beams stopped working simultaneously so I'm thinking it might be a wiring problem?
Any advice or info would be greatly appreciated.
The headlights are connected in parallel, so only one supply wire for both bulbs.
There is a headlamp relay, so maybe that quit on you.
It is in the engine bay fuse box.
You could interchange it temporarily with another relay (like fog lights?) of the same colour, they are identical.
Otherwise you might have a bad steering wheel light switch.
Good luck,
Paul
DVOM the connector for source voltage.. very possible both bulb is BUM..
