2015 Sport 2.0T Limited: probably LED, not sure. Not enough light forward. Could be brighter. Sharp cutoff on low beam. Can't read unlighted overhead signs. No light to front/sides. Can't read signs on shoulder of road. When turning unlighted corners, or into unlighted driveways, or unlighted expressway entrances, there is no light from the car to light the corner. This car needs Cornering lamps!!!' Yes, I can flip on Highbeam, but cars in front or oncoming cars don't like it, and does not help when turning into dark driveways, etc.
2018 2.0T Limited with "LED Intelligent System" is the same as above except EVEN WORSE. yes, the headlights shift left or right when turning, but not nearly enough. Matter of fact, I owned the car for more than two months before I realized the headlights move ever so slightly, when turning a corner. SHOULD MOVE MORE.
Lights should be brighter. Lights should light more of the front/side. (Cornering lamps would be ok). I've had other cars with headlights that move when turning, so I know how they should operate.
Although in the past, I NEVER had problems with Quartz Iodine/Quartz Halogen or HID headlights, these LED headlights are not as good we are led to believe. Give me QI/QH or
HID.
Part or all the problem "could" be the headlight reflectors, not the bulbs. Don't know. What I do know is that the headlights on the 2018 SUCKS, and on the 2015 only Suck.
Other than the headlights, I love the cars.
HID.
