2007....fuse num 13..25A.....how to remove the fuse ?? Thanks.Start with the fuses. What year is the car?
Pull it out2007....fuse num 13..25A.....how to remove the fuse ?? Thanks.
What our main man says!!!Pull it out
lolwhat our main man says!!!
It was fuse alrite....couple of more issues...
Boot light and glovebox light is not switching on..fuses again ?
TIA.
Sent from my ONEPLUS A6000 using Tapatalk
Don't know what caused it to blow the fuse in the first place.It was fuse alrite....couple of more issues...
TIA.
Thanks...will check on the bulbs as thr seem to be no dedicated fuses for them in the manual.Don't know what caused it to blow the fuse in the first place.
This might come back to blow the fuse again (then again, might not)
Yeah, usually start with the fuses
Then go onto the actual bulbs, sockets, checking power and grounds, switches
Good luck
Looks like the boot light has switch/earth issue....it works if i touch the one connector to car body....else its not working...where can i get wiring diagram of accent 2007 ? Thanks.Thanks...will check on the bulbs as thr seem to be no dedicated fuses for them in the manual.
The switch needs to be grounded. You proved the problem.Looks like the boot light has switch/earth issue....it works if i touch the one connector to car body....else its not working...where can i get wiring diagram of accent 2007 ? Thanks.
I am only grounding the socket of the bulb...where is the actual switch located for the boot bulb ?The switch needs to be grounded. You proved the problem.
Probably the door switch. Does the dome work?I am only grounding the socket of the bulb...where is the actual switch located for the boot bulb ?
Dome ? If u mean interior lights then yes they work fine...Probably the door switch. Does the dome work?
Is the socket 2 wire? If so the ground is not grounded. Find a ground for it.Dome ? If u mean interior lights then yes they work fine...
It has a green and red wire on one side and brown on other side....so i have to look where the green wire ends ??Is the socket 2 wire? If so the ground is not grounded. Find a ground for it.
Trunk Lamps & Switch location info attached.Looks like the boot light has switch/earth issue....it works if i touch the one connector to car body....else its not working...where can i get wiring diagram of accent 2007 ? Thanks.
Thanks for that any chance u can share the ETM ?Trunk Lamps & Switch location info attached.
