2011 Santa Fe LTD 4cyl, 2wd: 2021 Tucson LTD 4cyl, 2wd
How difficult is it to replace the rear lift gate arms? Ours are starting to not go up all the way. Makes it easier to close but prefer it go all the way up. 2011 LTD. Where is a good place to get the Hyundai replacement part? Is it a special nut like a torx or something. Thanks,
they're easy to replace. A clip holds the ends in but just pop out.
It depends on you options where you are. Length is usually the only criteria. I've not replace mine so you'd have to search. Whether Amazon or eBay has them or local parts shops/chains.
You can find them on Amazon and Ebay. I replaced the lift struts on the lift gate and window of The Bride's Tucson and also the lift gate on my old '01 Santa Fe. Like Trip said, it's easy and quick but it's a two person job - one to swap out the parts and the other to hold the lift gate up.
Thanks for the replies guys. I will check my local Hyundai dealer and get the part number and look for the lowest price on an OEM set.
