1 - 9 of 9 Posts
the screws are stripped on my license plate... i want to get it off but i can't get those screws out!
edit: i'm not just saying this as a statement, i'm asking if anyone has any suggestions on how to get them out
SENIOR MODERATOR
How far can you get them out? If you've got enough room to get a pair of needle-nose pliers in there, lock it down snugly on the head of the screw and turn while pulling out. If this doesn't work, get a friend to help apply some rear pressure on the head of the screw to help it get past the stripped portion. I had an issue with the screws holding in the side marker light on my old Santa Fe and it took me at least an hour to get them free so just be forewarned, some swearing and frustration might be in your future.
Don't be afraid to improvise and good luck! :thumbsup:
The screws fasten into plastic so if they are turning but not backing out it may be as simple as trying to get something thin like a putty knife or small screwdriver under the head of the screw. Then you can exert some upward pressure on the head of the screw as you are turning it and it may come out.
You may want to try putting a rubberband over the screw than trying to unscrew it. I've done this several times. The rubberband gives you more surface area to grip on the screw and the screwdriver.
Be prepared to ruin your license plate. I pulled mine out after fighting it and did it by pulling it out with the plate.
Shoulda replaced both at the time but didn't ..... now the other one is stripped.
Discussion Starter #8
QUOTE (craigbrooks @ Oct 25 2010, 05:55 PM) index.php?act=findpost&pid=366225
what exactly did you pull out? just the screws and the plate came with it? or like the actual things they screw into
The white plastic thing that the screw goes in. The doohickey that is causing your/our problem.
Fortunately I was changing plates so ripping the plate up was not a problem.
1 - 9 of 9 Posts
