So both of my lights are out on my 2014 sonata and put in new bulbs and they still don’t work. Any help would be appreciated. Is there a fuse that goes to those bulbs? All the other lights work in the rear of the car.
2007 Honda CRV
Check to see if you have power and ground going to the bulbs
Sometimes the socket is corroded or ground??
It may be the wiring that flexes every time you open the back. As avisitor said first check for power and earth at the bulb sockets.
If the new bulbs work when the lens is removed Carefully position the lens when reinstalling, its easy to pinch the bulb socket or wires causing a bad connection
