I think I burned out a fuse for my LH (facing towards hood) tail light. Brake light still works, new bulb displays the same symptoms. I cannot find mention of the tail lights in either fuse box. Any help?
Check the one marked B/UP LAMP under the hood. It protects the circuit on a bunch of stuff. M/T - Back-Up Lamp Switch, A/T - Rear Combination Lamp (IN) LH/RH,
Rear Curtain Module, Navigation Head Unit, Electro Chromic Mirror, IPS Control Module.
There is also one marked Stop Lamp in the interior fuse panel.
I have never heard of a seperate fuses for right or left side
tail lights ….I think you have other issues then fuses possibly socket or wiring.
Did you ever find a solution, I have same issue replaced harness , still not working
