I ordered a package of 12 LEDs for my 2013 Sonata. I replaced the two map lights, two dome lights, courtesy lights on the doors, glove box light, trunk light and re-replaced the license plate lights. But... when I when I installed the drivers vanity light, under the sun visor, something happened and now non of the lights will turn on! In addition to that the clock above the radio doesnt work and also I cannot lock the car from the key fob. Booked an appointment with the dealer but I want to solve the problem before I have to go pay crazy $$$ for the dealer to look at it. I'm thinking it may be a fuse. Can someone please help me, I am desperate.
It is most likely the fuses, A lot of times when you switch out the lights the leds will overload the circuit in a lot of cases. Check your fuses that is most likely the issue. I hoped I helped good luck
MODERATOR
Please post your issue at the respective forum for better respond.
