Hey guys I have my cat tinted and changed out the lighting to LEDs however he couldn't change the front signals because there is only one power wire and the signal lamps on the dashboard would always stay illuminated Has anyone been successful in upgrading these lights? Any info is appreciated
Yes, I changed mine out. You can't mess up polarity, because those bulbs only go in one way unless your model is a flasher only. If so, they just need to be put in 180 degrees from how they are in. A steady dashboard signal light indicates that you have a burnt out light on that side. Incorrect polarity should show the same sign.
The next issue that may show up with LED's is hyper flash. This is where the bulb flashes about twice the normal speed. 50W 6Ohm LED Load Resistors should take care of that though.
