I've been asking this question since I got my Sonata! Incandescent bulbs for the reverse, license plate, and vanity lights! Why!?!?! I replaced the reverse lights (too easy) and the license plate lights (very easy), and I am not what most would consider a handyman. I love the look of the LEDs. I replaced the license plate lights on my wife's Palisade but I still have to do the reverse lights. I will eventually get to the vanity bulbs.It is amazing how much better the LED reverse lights work over the factory ones. Why do they even bother using incandescent bulbs?
Even during the day, you can see the difference.
I totally agree. That's one of the first things I did, replace all non LEDs. Makes such a big difference.I've been asking this question since I got my Sonata! Incandescent bulbs for the reverse, license plate, and vanity lights! Why!?!?! I replaced the reverse lights (too easy) and the license plate lights (very easy), and I am not what most would consider a handyman. I love the look of the LEDs. I replaced the license plate lights on my wife's Palisade but I still have to do the reverse lights. I will eventually get to the vanity bulbs.
I got them from superbrightleds.com. You can put in your vehicle info and the right type bulbs will pop up.What is the part # for the reverse and license plate led bulbs?
In icy & cold conditions the lenses can freeze over with slush.. not necessarily in your example but elsewhere on the vehicle including the headlamps..It is amazing how much better the LED reverse lights work over the factory ones. Why do they even bother using incandescent bulbs?
Wouldn't that be the case with any and all lights?In icy & cold conditions the lenses can freeze over with slush.. not necessarily in your example but elsewhere on the vehicle including the headlamps..
Yes .. they have returned back to incandescent traffic lamps in certain areas where lamps are prone to snow & ice buildup. My headlamps were "froze over" with ice this evening, after several minutes they eventually melted, not the case possibly with LED unfortunately.Wouldn't that be the case with any and all lights?
It is easier to control cutoff line with the projector lens. That is why LEDs retrofits in reflector style housing does an excellent job in blinding everyone. Here is a good video about that:I find the LED's blinding & piercing to oncoming traffic but another issue, I wonder why they went to the projector style.
I find the factory projectors are blinding, yet some of our our intersections I believed are pitched so that oncoming standing traffic is facing slightly uphill.It is easier to control cutoff line with the projector lens. That is why LEDs retrofits in reflector style housing does an excellent job in blinding everyone. Here is a good video about that:
we had 2 2016 elantras with reflectors. i put led in both cars, NO adjustments, and never had anyone flash or complain. i had a friend who was retired hiway patrol, and he stood outside his yard while i drove by, and he said he could tell the lights were brighter, and, of course, whiter, but not blinding at all. he said that if he saw them while on patrol, he could tell they were different, but that is all. i later changed both cars to projectors, and i think the reflectors cast much better light
Try to pass UK's MOT with LED retrofit. Good luck with that.Gazwould] The crack of LED bulbs producing a correct beam pattern is to place it in the same position as the original filament . [ATTACH type="full" alt="454036 said:454036[/ATTACH]
