On another 2009 car I had, the fog lights were pre-wired and only had to be plugged into the new lights I bought, but, I had to change the lights switch stalk on the steering column in order to give the CPU a command to turn on the fog light relay if I wanted to use the existing wiring. The replacement light switch stalk with the fog-light position was not expensive and was easy to install.
Frank 2017 Sonata SE with 10K miles
