Hi i have leak from the bottom of this . Can engine tell me what part it is? Car that Hyundai santa Fe 2011
445822
That's the fuel filter. There's often a sensor screwed onto the bottom of it that detects any water in the fuel. Make sure the sensor is fully screwed in.
Ok I will try if not I change all part . Thank you . Did that can something to do whit losing cooling fluid becouse this is only place when I found leak?
No, there is no cooling fluid in the fuel filter. If it's leaking it will be diesel, which smells very different from coolant.
