Hi every one,
Has anyone fitted a towbar to a Hyundai Lantra 1999, if so is their a wiring socket for the towbar electrics?
Cheers Sean
welcome to the forums sean :00000732:
you will have to splice the wiring from the tow bar plug into the vehicle wiring one wire at a time (lights, brake lights, indicators etc.)
Thought as much, does anyone know where i can get a wiring diagram as my booklet is not much help
you don't really need one. pull the wiring connector off the back of the rear light cluster and then use a test light to determine what wire works each bulb (stop light, indicator etc.)
