Hello All,
I have a santaFe DM 2.4L petrol SUV. Wanted to run wires for dash cam rear. I tried removing the cut-out covers on the passenger side luggage compartment. There is a large and a small cover. Tried the large one it seems it has some sort of clips at the four corners. I do not want to remove the whole trim. Anyone removed this before. Does it require a special trim removal tool?
Any help will be appreciated. I have attached a picture with the covers circled as 1 and 2.
Regards
Ron
Having trim removal tools is an asset. You can use the tool to pull the trim backwards enough to run the cable and tuck it under the trim. I ran my rear camera DVR cable under this trim and mounted it next to the luggage light. The hardest section is near the small rear window.
