Hi. I have an issue with my 2007 CRTD CDX + , 2.2 l, Diesel Automatic. (127.000 m)I have browsed through the threads but can't seem to find a matching one.
Recently the car started to shudder when engine first started and even stalled twice when put into reverse. However after turning ignition off and back on again all was fine.
The second issue was when first driving off , there was only very little acceleration for the first 3 seconds and then it would suddenly kick in. The engine revs normal in Neutral.
The car drives and accelerates without issues after the first three seconds.
As the shudder problem was getting worse I took it to my local independent garage and after some tests it turned out that the DPF was faulty and was reaching extreme temperatures after only a short drive .
DPF has been replaced and the shudder / stalling issue seems to be resolved but the acceleration issue remains without obvious fault .
Garage spoke to local Hyundai dealer who unfortunately weren't much help.
Has anyone experienced this issue ?!
