1 - 1 of 1 Posts
KSPORT's Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. Made from high quality 6061 Aluminum with T6 for increased hardness.
Kontrol Pro
•36 levels of adjustable damping
•Made from high quality 6061 aluminum with T6 for increased hardness
•Compression/Rebound adjustable
•Adjustable spring perch for height adjustment
•Adjustable body allowing maximum suspension travel
•Pillowball top mount with adjustable camber (not available for some models)
•Monotube high pressure design reduces oil leakage
•Electroplated body for protection from corrosion and rust
•One year limited warranty
Accent - 2000 ~ 2004 - - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Alum Top Mnt
Azera - 2006 ~ 2011 - 2.7L - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
Azera - 2006 ~ 2011 - 3.3L and 3.8L - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
Elantra - 1996 ~ 2000 - - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Elantra - 2001 ~ 2010 - - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Genesis - 2008 ~ 2012 - Coupe - 2.0L Turbo - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Uses Rr OEM Mount
Genesis - 2008 ~ 2012 - Coupe - 3.8L v6 - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Uses Rr OEM Mount
Genesis - 2008 ~ 2012 - Sedan - 4.6L v8 - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Uses Rr OEM Mount
Sonata - 2000 ~ 2004 - - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Uses Rr OEM Mount
Sonata - 2005 ~ 2010 - 2.4L Engine NF - Height/Ride Adj - 36 dampening levels - Fr Alum Top Mnt / Rr Alum Top Mnt
Sonata - 2011 ~ 2012 - - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Alum Top Mnt
Tiburon - 1997 ~ 2001 - - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Tiburon - 2003 ~ 2008 - - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Tucson - 2005 ~ 2010 - 2WD DX - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
GT Pro
•Inverted steel shock absorber for durability
•Lower center of gravity and higher chassis rigidity
•Designed to reduce friction for cooler shock oil temperature
•Inverted design like vehicles in WRC and all JGTC cars
•36-way adjustable damping
•Made from high quality 6061 Aluminum with T6 for increased hardness
•Adjustable spring perch for height adjustment, •Adjustable body allowing maximum suspension travel
•Pillow Ball Top Mount w/ adjustable camber (not available for some models)
•Monotube High Pressure Design reduces oil leakage
•One Year Limited Warranty
Elantra - 2001 ~ 2006 - - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Tiburon - 2003 ~ 2009 - - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Rally Spec GR (Gravel) or Rally Spec AR (Asphalt)
•Special designed springs for rally conditions
•Extended Piston Stroke
•Reinforced internals to withstand extreme track conditions
•Compression/Rebound adjustable, Adjustable spring perch for height adjustment
•Pillowball top mount w/ adjustable camber (not available for some models)
Accent - 2000 ~ 2004 - - For Asphalt - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Alum Top Mnt
Elantra - 1996 ~ 2000 - - For Asphalt - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Elantra - 2001 ~ 2010 - - For Asphalt - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Tiburon - 1997 ~ 2001 - - For Asphalt - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Tiburon - 2003 ~ 2009 - - For Asphalt - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Elantra - 1996 ~ 2000 - - For Gravel Ralley - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Elantra - 2001 ~ 2010 - - For Gravel Ralley - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Tiburon - 1997 ~ 2001 - - For Gravel Ralley - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Tiburon - 2003 ~ 2009 - - For Gravel Ralley - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Version RR
•Aggressive valving and spring rates
•Race applications only
•Pillow ball top mount w/ adjustable camber (not available for some models)
Accent - 2000 ~ 2004 - - For Road Racing - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Alum Top Mnt
Elantra - 1996 ~ 2000 - - For Road Racing - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Elantra - 2001 ~ 2010 - - For Road Racing - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Genesis - 2008 ~ 2012 - Coupe - 2.0L Turbo - For Road Racing - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Uses Rr OEM Mount
Genesis - 2008 ~ 2012 - Coupe - 3.8L v6 - For Road Racing - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Uses Rr OEM Mount
Tiburon - 1997 ~ 2001 - - For Road Racing - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Tiburon - 2003 ~ 2009 - - For Road Racing - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Version DR
•Valved and sprung for drag racing; Proven to reduce 60 ft and elapsed times
•Includes shock dyno results, and tuned to your needs
•Adjustable spring perch for height adjustment, Adjustable body allowing maximum suspension travel
•18 Month Limited Warranty
Elantra - 1996 ~ 2000 - - For Drag Racing - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Elantra - 2001 ~ 2010 - - For Drag Racing - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Tiburon - 1997 ~ 2001 - - For Drag Racing - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
Tiburon - 2003 ~ 2009 - - For Drag Racing - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Rr Pillowball Up Mount
GO TO NOPI KSPORT Catalog for model specific images and details
Contact the salesmen below or PM me for our best deal on KSPORT Coilover Systems
1 - 1 of 1 Posts
