Not see much for odd noises from the 2.7, but you might look at your crank damper for seperation of outer ring (pulley) from center hub.
A/C compressor could make noise, does it change with clutch off or on ?
Have had chains on top of head that ties the cams toghter, but that is more of a hash type noise I think.
If engine neglected (missed oil changes here-there), might could start a rod/main knock, but that is something we dont see, had 1 drop a cylinder liner on #6, but the engine would not run there.
Just spend some time with ear probe (long skinny screwdriver work good), take the drive belt off to take alt - a/c - p/s out of the loop, see if it go away or still there, that;ll cut some of the background noise. Have heard of random drive plate cracking, see if it change tone when put in gear and load the throttle a little bit (light stall test).. try it in reverse and drive..
