The rubber piece on my key fob wore out and couldn't lock the car remotely, a bit of a nuisance having to use the key which only locks all doors when using the driver's side lock. A new fob was far too expensive.
There are quite a few Ebay sellers with new rubber bits but I'm too impatient to wait for postal delivery.
Anyhows, the rubber piece has moulded rods which go into holes and they operate the switches. So, found an O-ring with same diameter as the rod - 3.6 mm, and using a sharp knife cut a section of about 4 mm long, put that in the hole and covered it with a piece of electrical tape. Voila, my key fob works again.
