On the SE, do you have to press the lock button twice in order to activate the alarm? I notice that when you press it once, it locks the doors and the red light comes on. When you press twice then it will start blinking.
I'm not sure about using the FOB. Honestly, I never take mine out of my pocket (which rocks). I just use the button on the door handle. Anyway, when I lock the door, the red light goes steady-on for ~20 seconds or so, then starts blinking.On the SE, do you have to press the lock button twice in order to activate the alarm? I notice that when you press it once, it locks the doors and the red light comes on. When you press twice then it will start blinking.
Well, that red light blinks all the time in my car, even with the car unlocked. Must be for something else too. Or maybe it blinks at a different rate when 'armed'.
Hey, does this car even have an alarm? My M3 doesn't; you need to buy the 'alarm kit' and have dealer code it. I don't even see a hood switch on this car, so at least the hood is not protected. But with a coded key, it's very hard to steal the car without keys. Some people say it's possible to steal BMWs with the 'smart key', but that has never happened in the US for what I've read. Not worried about that at all.
On the side of the window, there is a sticker saying equipped with hyundai security. Opening the door should trigger the alarm since there is a pin switch in the door. The only way to test the window breakage sensor is to either tap hard on the glass and see if it gives a warning beep or goes off. Just be careful no to tap too hard or you might break the window all together.
Thanks for the tip. I didn't know I can lock my car by just pressing the black button. You are also right about the red light, it does stay on for 20 seconds then blinks....I guess I was doing it right from the get go.I'm not sure about using the FOB. Honestly, I never take mine out of my pocket (which rocks). I just use the button on the door handle. Anyway, when I lock the door, the red light goes steady-on for ~20 seconds or so, then starts blinking.
You can also change this behavior in the car settings menu using the trip/reset buttons on the steering wheel. I have mine set to unlock everything on the first push (cuz I'm lazy).Thanks for the tip. I didn't know I can lock my car by just pressing the black button. You are also right about the red light, it does stay on for 20 seconds then blinks....I guess I was doing it right from the get go.
I don't know if anyone knows this already, but pressing the black button twice on your door handles unlocks all of your doors.
