· Registered
I just realized this two days ago, and it's not major, I know. I just have a little ocd when I know something is wrong with the car but not know why.
The hazard light that usually blinks when I lock the car. It doesn't blink anymore. When I press the lock button on the key fob twice, it doesn't honk anymore.
Why is this? Anyone knows? I wanted to check the fuses and see if any of them is blown, but gave up halfway after checking the right half of the fuse box. (I can't get the left ones to come out)
· Registered
Been wrecked, hood replaced ...
Check hood switch and the bumper fit.. Actually open the hood, depress switch with finger, and try remote..
· Registered
I didn't know what term to search for, but I guess I could've just search for key fob and it popped up...
I just checked the hood but can't find what I'm looking for so I gave up...
But I checked all the four doors to make sure they're locked when I press the lock button on the fob. Apparently the rear left door doesn't lock as it should, and that's what's causing the problem.
I called the dealer to make an appointment to check on it. He said I'm looking at around $250 if the lock actuator has to be replaced, since the whole "latch and everything" has to be replaced as well. Shouldn't it be covered under warranty?
· Registered
QUOTE (KIDRoach @ Jun 11 2010, 03:31 PM) index.php?act=findpost&pid=332148
If you're still in the 5/60 B-B it is covered.
