Just installed a solid strut bar and a pedal set from SHARK RACING!
I also have the diffuser cutted to 2.4 dual exhaust spec, havent install it yet tho!
I had to seperate posts! Too many image!
#1 Solid Strut Bar http://sharkracing.com/acecart/bin/shop.cgi?action=view&itemID=solidstrut&cate=012104000
A torque wrench is a must! And a socket of 9/16 (deep one)
The wrapping is really solid, no questions nor issues found!
They also included these rings? or spacer? Idk....
Before
After
Before
After
I placed the rings under the bar, and torqued the nuts to 45lbs.
I test drove it right after the installation! HUGE IMPROVEMENT NO KIDDING! Tighter, stronger, A+ performance!
QUOTE (robspeedGLS @ Nov 5 2010, 07:41 AM) index.php?act=findpost&pid=369188
Those "rings" are washers. They go between the nut and the strut bar.
so I did the installation wrong? Becuase I noticed there will be a space in between the base and the bar if you don't place the washers between the bar and the base! So that's why I thought to place them in between bar and base to eliminate the space.
