[Hello, new to this site, Has anyone installed door lights on a ix35 highlander 2011,
Mine currently has just the reflectors, I would like to convert them to working door lights,
At first inspection the doors now use connectors to the car body which would make running any lighting cable into the door extremely hard.
Unless there is already another circuit I can tap into.
HI
Tap into the power window wire, every time you turn on the key. They will lit up. You won't see them glow in day time with door closed anyway.
Or go advance, tap to the dome light circuit. Door opens, light lits. That will be a tedious job.
When my car was new, I planned to put led flat board inside the red cover, even removed the cover to have a look. But lost interest later.
GL
Ta
was going to run a wire from foot kick panel through the body then into door via the cable line inside the rubber tubing only to discover the cable harness is now a plug setup to the car body.
:-( dang.
