So i cannot get my car to start. It does not make a sound when i try to start, and the gear is stuck in park. Thought it was the battery so i replaced it, but it still does nothing except the dome and the park lights come on.
first thing i would check would be the fuses..... do the headlights and all other electrics work with the new battery? is it similar to trying to start the car when its in drive?
like eddie said, check the fuses and other electrical stuff to make sure they are working, if everything is working then you may have a bad starter or relay, the relay is easier to check and replace if necessary than the starter
