1 - 9 of 9 Posts
Hey all,
I have been having an issue...I think, with my car basically since I got it 3 months ago. Everything about the car has been great so far, but one thing that concerns me is that whenever I have to drive quickly through the gears, it seems like the RPMs rev up, and I get very little power from it. I mean, I know my 2004 Hyundai Elantra GT isn't the fastest car in the world, but it's to the point where like I'm THAT guy when a light goes green and I am getting in peoples way for a little bit. Once I get up to speed, no problems at all.
Here is a video, it's kind of hard to see when I'm shifting, and when the RPMs are just jumping. I honestly don't know if this is normal for a manual, but I think the fact that I feel almost ZERO pull when I shift to the next gear, and I have to constantly watch that I don't push the accelerator down too hard...isn't normal. If I push it decently far, instead of a steady increase up, it just seems to fly into high RPMs, but not give me much power anyway. I think around 21 seconds in this video, that was one time where I shifted then put the gas pedal down and the RPMs jumped
Possible issue with car? - YouTube
Is this normal or a problem?
Clutch is solid connection between engine to trans input shaft.. engine speeds up and car not increase speed...... clutch is slipping.
Time for clutch.. smell anything burning ?
Clutch disk
Pressure Plate
Release bearing
Resurface flywheel or replacement
2 bottle of Hyundai MTF oil (GL-4, 08950-00020)
Remove restrictor from slave cylinder inlet, flush clutch hydraulic so it new clean fluid
I have gotten a few quick whiffs of a strange smell, but only extremely briefly. I really didn't think anything of it.
Sigh, I guess I'll drive on it for a little bit, perhaps bring it to the mechanic to take a look at, and get it replaced in a few months. Thanks for the input, I appreciate it!
Not anything to look at,, you ready for clutch.. get it while the flywheel not been overheated from friction of slipping clutch.. that'll save you maybe $300
not having to buy flywheel if it can just be resurfaced to clean it up
DId you figure out for sure what your issue truly was?
Yup. Slipping clutch. attempting to replace it today with my brother. Wish us luck! haha
I brought it into the mechanic and they were like WOAH, that clutch is seriously slipping!
@Scottyent: "...one thing that concerns me is that whenever I have to drive quickly through the gears..."
Uh, just how many "whenever's" have you been required to drive quickly through those gears? :rolleyes: Due to signal-light-to-signal-light adventures? :D
Good luck on the install. Take your time and don't rush the job. Otherwise you might see the throw-out bearing laying on the floor and stroke out. I know someone I used to work with that did this. Not the stroke, but left out the throw-out bearing. "Do-Over!"
i'm quite convinced that adjustment of the pedal and therefor pressure on the clutch bearing is responsible for many failures of the LC accent clutch bearing - a well known issue.
worthwhile to ensure that there is enough pressure on it after replacement to ensure that it isn't walking on the pressure plate like an ass....like what trashed 3 bearings in my accent!
just a thought....
1 - 9 of 9 Posts
